Torstein
Oct 09, 2017Aspirant
Google Drive Sync
Model: Readynas 2120 with 4x 1TB disks. Firmware: 6.8.1 I wanted to report this problem directly, but could not find a way to do it. We are using the google drive beta to sync with our ReadyN...
Marty_M
Oct 26, 2017NETGEAR Employee Retired
Hello Torstein,
From the complete logs of the NAS, there should be a specific log for google-drive and it should contain logs of the error of the previous occurance. Please check the logs as it may contain information that what might be causing the problem.
Marty_M
NETGEAR Community Team
Torstein
Nov 08, 2017Aspirant
Here is the log file.
It has been busy days, so this problem was set aside for a while.
What i see here is that 31st of october, the service stopped because "the Local path /data/ahlin01/Google Drive/ does not exist"
There were no changes in the name of the path at that time. So that it just stops, and does not try to refresh is kind of annoying. This also happened once before, at aug 23rd.
No as i started it up again, there was tons of errors, probably due to the changes thats been made in the meantime.
