ajbarnard1977
Apr 03, 2020Aspirant
Google Drive Sync
I recently enabled Google Drive sync and noticed that when I delete something off my local NAS it does not remove it from Google Drive. Everything is done syncing, and if i edit/change a file on my N...
JohnCM_S
Apr 04, 2020NETGEAR Employee Retired
Hi ajbarnard1977,
I just tested it the Google Drive sync on our NAS running on 6.10.3 and when I delete files on NAS, it will also delete those files on Google Drive.
You may download the NAS system logs, then check the google-drive.log. You may able to find some clues there.
