ajbarnard1977
Apr 03, 2020Aspirant
Google Drive Sync
I recently enabled Google Drive sync and noticed that when I delete something off my local NAS it does not remove it from Google Drive. Everything is done syncing, and if i edit/change a file on my N...
ajbarnard1977
Apr 13, 2020Aspirant
Hi John. I did some more testing today and here are the results.
I set bidirectional on my cloud syncs.
Created a test file called 'test123.txt' on NAS, it uploaded OK to G-Drive
Deleted the file called 'test123.txt' from NAS, did not delete from G-Drive, re-synced down to NAS after about a minute
Created a file called 'testAAA.txt' on NAS, it uploaded OK to G-Drive
Delete the file called 'testAAA.txt' from G-Drive, it did not delete from NAS
google-drive.log below. I don't see anything for test123.txt, and i've re-downloaded the logs several times.
Apr 13 14:56:47 alcatraz ng-csd[10003]: Failed to set local modified time. _nodeLocalPath = /NAS-Data/NAS/New Text Document.txt, modifiedTime = 2020-04-13T21:56:45Z, exception = File not found: /NAS-Data/NAS/New Text Document.txt
Apr 13 14:56:47 alcatraz ng-csd[10003]: E0413 14:56:47.121603 10008 SyncUpsyncFile.cpp:440] Failed to set local modified time. _nodeLocalPath = /NAS-Data/NAS/New Text Document.txt, modifiedTime = 2020-04-13T21:56:45Z, exception = File not found: /NAS-Data/NAS/New Text Document.txt
Apr 13 14:57:10 alcatraz ng-csd[10003]: Failed to open file /NAS-Data/NAS/New Text Document.txt
Apr 13 14:57:10 alcatraz ng-csd[10003]: Failed to upload file. localPath = /NAS-Data/NAS/New Text Document.txt, remotePath = /_Alcatraz-NAS/New Text Document.txt
Apr 13 14:57:10 alcatraz ng-csd[10003]: E0413 14:57:10.662928 10008 GoogleDriveIOClient.cpp:530] Failed to open file /NAS-Data/NAS/New Text Document.txt
Apr 13 14:57:10 alcatraz ng-csd[10003]: E0413 14:57:10.666860 10008 GoogleDriveFS.cpp:697] Failed to upload file. localPath = /NAS-Data/NAS/New Text Document.txt, remotePath = /_Alcatraz-NAS/New Text Document.txt
Apr 13 14:57:10 alcatraz ng-csd[10003]: E0413 14:57:10.666949 10008 SyncUpsyncFile.cpp:400] Failed to upload file. local file = /NAS-Data/NAS/New Text Document.txt, remote file = /_Alcatraz-NAS/New Text Document.txt. Error #12: Failed to open file /NAS-Data/NAS/New Text Document.txt
Apr 13 14:57:10 alcatraz ng-csd[10003]: E0413 14:57:10.667109 10008 SyncUpsyncFile.cpp:440] Failed to set local modified time. _nodeLocalPath = /NAS-Data/NAS/New Text Document.txt, modifiedTime = 2020-04-13T21:57:10Z, exception = File not found: /NAS-Data/NAS/New Text Document.txt
Apr 13 14:57:10 alcatraz ng-csd[10003]: Failed to upload file. local file = /NAS-Data/NAS/New Text Document.txt, remote file = /_Alcatraz-NAS/New Text Document.txt. Error #12: Failed to open file /NAS-Data/NAS/New Text Document.txt
Apr 13 14:57:10 alcatraz ng-csd[10003]: Failed to set local modified time. _nodeLocalPath = /NAS-Data/NAS/New Text Document.txt, modifiedTime = 2020-04-13T21:57:10Z, exception = File not found: /NAS-Data/NAS/New Text Document.txt
Apr 13 14:57:35 alcatraz ng-csd[10003]: Failed to get sync action. Error #12: File not found: /NAS-Data/NAS/testAAA.txt
Apr 13 14:57:35 alcatraz ng-csd[10003]: Failed to upsyncChange node. local node path = /NAS-Data/NAS/testAAA.txt
Apr 13 14:57:35 alcatraz ng-csd[10003]: E0413 14:57:35.483798 10003 SyncUpsyncFile.cpp:243] Failed to get sync action. Error #12: File not found: /NAS-Data/NAS/testAAA.txt
Apr 13 14:57:35 alcatraz ng-csd[10003]: E0413 14:57:35.483914 10003 SyncEngine.cpp:1272] Failed to upsyncChange node. local node path = /NAS-Data/NAS/testAAA.txt
Apr 13, 2020 02:56:49 PM | /_Alcatraz-NAS/New Text Document.txt was moved or renamed to /_Alcatraz-NAS/test123.txt on Cloud Drive. | |
Apr 13, 2020 02:57:10 PM | Uploading /NAS-Data/NAS/New Text Document.txt ... | |
Apr 13, 2020 02:57:10 PM | Uploading /NAS-Data/NAS/testAAA.txt ... | |
Apr 13, 2020 02:57:12 PM | /NAS-Data/NAS/testAAA.txt was uploaded to Cloud Drive. | |
Apr 13, 2020 02:58:06 PM | Downloading /NAS-Data/NAS/testAAA.txt ... | |
Apr 13, 2020 02:58:06 PM | /NAS-Data/NAS/testAAA.txt was downloaded to local. |
ajbarnard1977
Apr 14, 2020Aspirant
Wanted to wait a few hours to see if the sync (delete) would happen. As you can see, the file "test-delete.txt" is gone from the NAS, but it still exists on G-Drive.Any idea what could be going on?
I attached a screenshot of G-Drive and my share folder
Thanks,
Drew
