ajbarnard1977
Apr 02, 2020Aspirant
Google Drive Sync
I recently enabled Google Drive sync and noticed that when I delete something off my local NAS it does not remove it from Google Drive. Everything is done syncing, and if i edit/change a file on my N...
atsob
May 09, 2020Guide
I have the same problem on both RN204 & RN214, on 6.10.3 and for the same google account drive.
When delete a file on NAS, it is not deleted on the Google side.
May 10 07:34:31 NAS-3-01 ng-csd[2796]: Failed to get sync action. Error #12: File not found: /data/Cloud/Google Drive/Ticket-1.pdf
May 10 07:34:31 NAS-3-01 ng-csd[2796]: Failed to upsyncChange node. local node path = /data/Cloud/Google Drive/Ticket-1.pdf
May 10 07:34:32 NAS-3-01 ng-csd[2796]: E0510 07:34:31.978382 2796 SyncUpsyncFile.cpp:243] Failed to get sync action. Error #12: File not found: /data/Cloud/Google Drive/Ticket-1.pdf
May 10 07:34:32 NAS-3-01 ng-csd[2796]: E0510 07:34:31.979728 2796 SyncEngine.cpp:1272] Failed to upsyncChange node. local node path = /data/Cloud/Google Drive/Ticket-1.pdf
Any ideas?
- AndreCamJul 08, 2020Tutor
Same problem on my RN102, on 6.10.3.
Files upload fine, HOWEVER, when I delete a file on NAS, it is not deleted on the Google side.
PS. The folder sync is set to Bidirectional.
- ajbarnard1977Jul 08, 2020Aspirant
Yeah, they told me to open a support ticket. I have a feeling they just want to charge me support level prices to tell me to factory reset / format the drives :smileymad:
