toledotom
Dec 12, 2019Tutor
Have to keep restarting Amazon CloudDrive sync after upgrading from 6.9.4 Hotfix 1 to 6.10.2
Since upgrading from 6.9.4 Hotfix 1 to 6.10.2, the Amazon CloudDrive sync has to be restarted continuously. I do this by going to the admin page, Cloud, AmazonDrive button, settings, the settings bu...
toledotom
Dec 12, 2019Tutor
Should mention in addition to above, the sync is partially working; if I create or copy a file locally it always makes it up to AmazonCloud. But not the other direction - if I add to the Cloud (either directly through web or sent up by another synced ReadyNas it doesn't make it back down as explained above.
