kalyanraju's avatar
kalyanraju
AC1750 Smart WIFI Router - Restarting frequently after firmware Upgrade
Hi Team, I have purchased AC1750 Smart WIFI Router on 6th Dec 2018, it worked fine till the last firmware upgrade. It is restarting quite frequently. Could you please help us. Serial number : 59B3887WA0299 Product: R6400v2
  • kalyanraju wrote:
    Product: R6400v2
    It is an R6400v2. AC1750 is a wifi speed.
    What firmware version do you have on the device?
    A number is more useful than "the latest". (It may not be by the time people read this.) There can also be newer versions, or "hot fixes", that do not show up if you check for new firmware in the browser interface.
    Have you tried a factory reset?
    How do I perform a factory reset on my NETGEAR router? | Answer | NETGEAR Support
    If you visit the support pages:
    Support | NETGEAR
    you can feed in your model number and find the documentation for your hardware.
    It will also have any firmware and drivers for your device.
    Look for the model number on the label on the device.
    Check the section in the manual on updating the firmware.
    Check the troubleshooting section in the manual.
  • michaelkenward's avatar
    michaelkenward
    kalyanraju wrote:
    Product: R6400v2
    Support | NETGEAR
    • kalyanraju's avatar
      kalyanraju
      Hi Team,
      As per my initial validation, AC1750 Smart WIFI Router is power cycling continuously if i connect iPad2 to the wifi broadcasted by the router. Could you please guide me steps to connect iPad2 with iOS 9.3.6. to the wifi provided by AC1750 Smart WIFI Router
      Router firmware version - V1.0.4.84_10.0.58
      iPad2 -  iOS 9.3.6.
        michaelkenward
        Read  my response  – there is no such things as an AC1750.
        You can say the same thing over and over again, but without adding some useful information you are not going to get much further.
        If you want Netgear to respond, use the official support system.
        Contact NETGEAR Support
        This place is essentially user-to-user.
        Good luck.
        You can help people to help you by providing the information suggested in this forum's header:
        Subject (Include model number and brief summary)
        Model (Recommended - Helps the community give the best answers)
        Body (Include additional detail including model version, firmware, OS and environment where relevant.)
        They are there for a good reason.
      kalyanraju
      Yes, I did factory reset but still its the same issue.
      Its working fine with other apple products expect iPad2 with iOS v.9.3.6.
      kalyanraju
      Thank you, hot fix firmware update fixed the issue.
      Firmware Verssion working:
      V1.0.4.94_10.0.69
