toledotom
Dec 12, 2019Tutor
Have to keep restarting Amazon CloudDrive sync after upgrading from 6.9.4 Hotfix 1 to 6.10.2
Since upgrading from 6.9.4 Hotfix 1 to 6.10.2, the Amazon CloudDrive sync has to be restarted continuously. I do this by going to the admin page, Cloud, AmazonDrive button, settings, the settings bu...
JohnCM_S
Dec 14, 2019NETGEAR Employee Retired
Hi toledotom,
On the Amazon Drive settings on the NAS, what is the sync direction selected? Is it on Bi-directional?
You may also download the NAS system logs, then check the amazon-drive.log. You might be able to find some clues there on what is causing the issue.
- toledotomDec 16, 2019Tutor
Sync is and has been set to bidirectional.
I test by logging into my amazon clouddrive account, and uploading a local file to the cloud in a particular folder. It should download back to my ReadyNas in the selected folder, but it doesn't unless I go through the manual 'kickstart' procedure described in my first post (settings, apply, etc.)
I did a test a bit ago, and it successfully synced but again, only after manually kickingstarting the process as above. Here is a log from the settings page of the Amazon Clouddrive under Cloud after successful manual kickstart:
Dec 16, 2019 09:17:42 AMAmazon Drive service started.Dec 16, 2019 09:17:42 AMStarting to index local drive. This could take a while. Please wait.Dec 16, 2019 09:17:48 AMIndexing local drive is complete.Dec 16, 2019 09:17:48 AMStarting to scan cloud drive for changes. It could take a while. Please wait.Dec 16, 2019 09:19:11 AMDownloading /data/AmazonCloudDrive/Personal/2017 Terrain/vzw-global-modem-usb730l-ug.pdf ...Dec 16, 2019 09:19:13 AM/data/AmazonCloudDrive/Personal/2017 Terrain/vzw-global-modem-usb730l-ug.pdf was downloaded to local.Dec 16, 2019 09:27:46 AMScaning cloud drive changes is complete.Dec 16, 2019 09:27:46 AMStarting to scan local drive for changes. It could take a while. Please wait.So clearly, things are in place for the sync to work, but it seems the Amazon drive service isn't always on; has to be 'kickstarted'. Is there a setting to keep this on somewhere?
- toledotomDec 17, 2019Tutor
Here are recent log entires from ReadyNas system log:
Dec 16, 2019 09:56:51 AM System: Unauthorized. It could be invalid user account credential or the app is not allowed to access cloud drive. Stopped syncing with Amazon Drive. Dec 16, 2019 09:56:42 AM System: Service protocol amazon-drive is enabled. Dec 16, 2019 09:53:27 AM System: Unauthorized. It could be invalid user account credential or the app is not allowed to access cloud drive. Stopped syncing with Amazon Drive. Dec 16, 2019 09:53:18 AM System: Service protocol amazon-drive is enabled. Dec 16, 2019 09:52:36 AM System: Unauthorized. It could be invalid user account credential or the app is not allowed to access cloud drive. Stopped syncing with Amazon Drive. Dec 16, 2019 09:06:37 AM System: Successfully sent alert message. Dec 16, 2019 09:06:20 AM System: Alert settings are updated. Dec 16, 2019 09:06:20 AM System: Alert contact information was saved. Dec 16, 2019 09:05:38 AM System: Alert settings are updated. Dec 16, 2019 09:05:38 AM System: Alert contact information was saved. Dec 16, 2019 09:00:18 AM System: Alert message failed to send. Dec 16, 2019 09:00:07 AM System: Alert settings are updated. Dec 16, 2019 09:00:07 AM System: Alert contact information was saved. Dec 16, 2019 08:59:04 AM System: Alert message failed to send. Dec 16, 2019 08:58:53 AM System: Alert settings are updated. Dec 16, 2019 08:58:53 AM System: Alert contact information was saved. Dec 16, 2019 08:57:23 AM System: Alert settings are updated. Dec 16, 2019 08:57:23 AM System: Alert contact information was saved. Dec 16, 2019 08:56:45 AM System: Alert message failed to send. Dec 16, 2019 08:56:33 AM System: Alert settings are updated. Dec 16, 2019 08:56:33 AM System: Alert contact information was saved. Dec 16, 2019 08:55:29 AM System: Alert message failed to send. Dec 16, 2019 08:55:18 AM System: Alert settings are updated. Dec 16, 2019 08:55:17 AM System: Alert contact information was saved. Dec 16, 2019 08:54:48 AM System: Alert message failed to send. Dec 14, 2019 04:18:44 AM System: ReadyNASOS background service started. Dec 13, 2019 05:36:31 PM System: Alert message failed to send. Dec 13, 2019 05:36:31 PM System: The system is shutting down. Dec 13, 2019 05:22:28 PM System: ReadyNASOS background service started. Dec 12, 2019 12:22:19 AM System: Alert message failed to send. So it looks like there is an authentication issue with Amazon CloudDrive that is causing the Amazon CloudDrive service to stop? But I can't find anywhere to check the authentication settings. And, if authentication is an issue, why would I be able to achieve a bidirectional sync by "kickstarting"?
- JohnCM_SJan 07, 2020NETGEAR Employee Retired
Hi toledotom,
It does look like an issue with the authentication. Have you tried leaving and then rejoining the NAS to the Amazon Drive?
