Eleniyan
Nov 11, 2017Aspirant
How to delect data in ReadyNas 102
I have ReadyNas 102 storage device (2 Bays), tried to delete data to free up space but everytime I refresh more data space is consumed. Currently without adding any data my storage have move from 20G...
BingkeX
Nov 12, 2017NETGEAR Expert
Hi Eleniyan,
Would you please check do you have snapshots for your shares?
Best Regards
Nov 12, 2017Guru - Experienced User
Also, please let us know what firmware is running on your NAS
- EleniyanNov 14, 2017Aspirant
Thanks for your response. Firmware - 6.9.0 and the snapshots cover half of the data space.
How can I delete the snapshots?
Thanks
- BingkeXNov 14, 2017NETGEAR Expert
Hi Eleniyan,
You need to delete snapshots on Shares page by click "Snapshots" button next to "New share" button on top-right corner. Then right click snapshots of your share to delete them.
If you don't want to keep the data of your share also, you can delete your share directly. This will also delete its snapshots. Then you can create new share to store your datas.
Best Regards.
- B_LNov 14, 2017NETGEAR Expert
You can go to shares, select one share, and click the snpshots button on the top right corner, and then delete the snapshots from there.
