kisa72
Nov 24, 2019Guide
How to see progress of ReadyNAS OS 6: Sync with Amazon S3
Hi, Thanks for taking the time to read my question. I've successfully connected my Readynas 104 to my AWS S3 storage as explained in the Netgear forum - ReadyNAS OS 6: Sync with Amazon S3. What I ...
kisa72
Nov 26, 2019Guide
Thanks for the reply Marc_V.
I'm unable to find a log option under Settings at all. Any thought as to where else it may be?
I'll also forward the idea onto the Ideas Exchange Board as you suggested.
Nov 26, 2019Guru - Experienced User
Download the full log zip file from system->logs. You'll find a log called amazon_s3.log in there. Though there could well be relevant informatoin in the other logs too.
- kisa72Nov 27, 2019Guide
Thanks for that.
I've looked in the S3 logs and it doesn't contain any info regarding the files transferred and although I can see files are trnasferring by looking at the AWS console, the logs are still showing issues such as "Invalid SQL statements".
So I have no idea what's happening there :(.
-- Logs begin at Fri 2019-09-20 19:01:43 ACST, end at Wed 2019-11-27 16:50:00 ACST. --
Nov 24 14:18:52 ReadyNAS systemd[1]: Started Amazon Web Service S3 client for ReadyNAS.
Nov 24 14:18:53 ReadyNAS ng-csd[30168]: Reset the cache. Invalid SQL statement: no such table: settings: no such table: settings
Nov 24 14:18:53 ReadyNAS ng-csd[30168]: W1124 14:18:53.580765 30168 FSCache.cpp:78] Reset the cache. Invalid SQL statement: no such table: settings: no such table: settings
Nov 24 14:19:38 ReadyNAS systemd[1]: Stopping Amazon Web Service S3 client for ReadyNAS...
Nov 24 14:19:38 ReadyNAS systemd[1]: Stopped Amazon Web Service S3 client for ReadyNAS.
Nov 24 14:19:39 ReadyNAS systemd[1]: Started Amazon Web Service S3 client for ReadyNAS.
Nov 24 14:19:40 ReadyNAS ng-csd[30271]: Reset the cache. Invalid SQL statement: no such table: settings: no such table: settings
Nov 24 14:19:40 ReadyNAS ng-csd[30271]: W1124 14:19:40.490993 30271 FSCache.cpp:78] Reset the cache. Invalid SQL statement: no such table: settings: no such table: settings
Nov 24 17:18:09 ReadyNAS ng-csd[30271]: File changed during upload
Nov 24 17:18:09 ReadyNAS ng-csd[30271]: E1124 17:18:09.123328 31296 SyncUpsyncFile.cpp:423] File changed during upload
Nov 26 15:25:53 ReadyNAS systemd[1]: Stopping Amazon Web Service S3 client for ReadyNAS...
Nov 26 15:25:54 ReadyNAS systemd[1]: Stopped Amazon Web Service S3 client for ReadyNAS.
Nov 26 15:25:59 ReadyNAS systemd[1]: Started Amazon Web Service S3 client for ReadyNAS.
Nov 26 15:26:00 ReadyNAS ng-csd[12893]: Reset the cache. Invalid SQL statement: no such table: settings: no such table: settings
Nov 26 15:26:00 ReadyNAS ng-csd[12893]: W1126 15:26:00.317327 12893 FSCache.cpp:78] Reset the cache. Invalid SQL statement: no such table: settings: no such table: settings- david_spittleJul 27, 2022Tutor
Did you ever find the log location?
I can only find the one when you download all of them.
- StephenBJul 27, 2022Guru - Experienced User
Likely events are logged in the systemd log (try using journalctl and see if you can find any entries for it).
