Mr404notfound
Dec 27, 2015Aspirant
I can't exceed 2mb/s NG 102.
Bonjour, Voila, je possede un Net Gear 102 et je dois faire un backup de mon pc. Le fichier etant compresser, je le transfert vers le Nas, mais impossible de depasser les 2mb/s. Mon probleme eta...
Dec 27, 2015Guru - Experienced User
What firmware is running on the NAS?
Is the AntiVirus service turned on? If so, try turning it off.
@Google Translate wrote:
Qu'est-ce firmware est en cours d'exécution sur le NAS?
Est le service AntiVirus allumé? Si oui, essayez de le désactiver.
- Mr404notfoundJan 08, 2016Aspirant
Appy New year,
Sorry for the late (and my english :smileywink: ),
i turn off the antivirus, but it have no effect, and i have no update for the firmware :smileysad:
- StephenBJan 08, 2016Guru - Experienced User
Mr404notfound wrote:
Appy New year,
What firmware does RAIDar 6 say you are running?
