tony359
Sep 13, 2019Apprentice
iDrive for ReadyNAS Pro 6 running OS6
Hi there I'm testing iDrive now that CrashPlan discount has ended. My PRO6 is happily running OS6. The app that I can install from the admin page says there is an update and links to a iDrive pa...
Sep 13, 2019Guru - Experienced User
tony359 wrote:
which current NAS shall I select so that I am given the proper version - which is assume it's the x86 version?
Yes, it's an x86 version. RN3xx, RN4xx, RN5xx, or RN6xx should all work.
Let us know how it works out.
- tony359Sep 13, 2019Apprentice
Thanks StephenB,
That worked ok!
So far I'm impressed by iDrive - particularly by the fact that it WORKS on the NAS without having to become a Linux engineer! :)
I'm just trying to find out if the backup incremental algorithm is as good as CrashPlan's and then I guess they have a new customer.
