tony359
Sep 13, 2019Apprentice
iDrive for ReadyNAS Pro 6 running OS6
Hi there I'm testing iDrive now that CrashPlan discount has ended. My PRO6 is happily running OS6. The app that I can install from the admin page says there is an update and links to a iDrive pa...
Sep 13, 2019Guru - Experienced User
tony359 wrote:
which current NAS shall I select so that I am given the proper version - which is assume it's the x86 version?
Yes, it's an x86 version. RN3xx, RN4xx, RN5xx, or RN6xx should all work.
Let us know how it works out.
tony359
Thanks StephenB,
That worked ok!
So far I'm impressed by iDrive - particularly by the fact that it WORKS on the NAS without having to become a Linux engineer! :)
I'm just trying to find out if the backup incremental algorithm is as good as CrashPlan's and then I guess they have a new customer.
