dagmarian
Feb 17, 2019Guide
Ignored Files when backing up Mac folder: unable to diagnose or resolve annoying glitch
My previous atttempt at rasing this issue - itself seemingly aslo ignored - can be found at https://community.netgear.com/t5/ReadyNAS-Cloud-Storage/Desktop-client-for-Mac/m-p/1658511/highlight/true#M...
Marc_V
Feb 19, 2019NETGEAR Employee Retired
Hi dagmarian
When backing up a folder on Mac I also get the same mesage where files are being ignored. Checking it, Finder showed folders that does not contain any files. Is yours showing a blank window?
Can you post screenshots of the issue you are getting?
Regards
dagmarian
Feb 21, 2019Guide
Hi Mark, thanks for responding.
I'm away from my ReadyNAS location for a few days so can't check latest.
I usually get a Finder window that shows some content, however I've never been able to make any connection with that content (files etc) and anything my backup may or may not be doing. In other words it feels that the generation of the finder view is either random or relates to some other system function / recent activity within the Mac.
- dagmarianFeb 24, 2019Guide
Attached is a screenshot of the notification from the desktop app.
I can confirm that the finder window that results from 'clicking to view' does not show me 13 files but seems to show something relating to my past use of Finder. i.e. having nothing to do with the readycloud backup function.
