vdotmatrix's avatar
Nov 10, 2021
Are Ethernet switch problems easy to diagnose?
My ethernet system is crippled. Some ethernet devices are not on the network anymore...
It will only work on 3 of 4 ethernet ports out of the R8000 router.
I disconnected the 8-port switch which has 3 of the 8 lights on when there is nothing plugged in to the switch.
So I read that something can happen to cause a loop that blocks ethernet signals from work on my home network. The system has worked for many many years.
Would a bad switch cause issues with IP address in the router ?
I have a GS116NA that I hope to open and install to replace the 8-port switch...
Is this a good choice for a home network upgrade?
  • I finally pulled the trigger and installed the new 16-port GS116NA ethernet switch.
    POOOOOF!
    Problems solved. Apparently it was a bad 8-port ethernet switch that gave up the ghost and was cause all kinds of problems that did not make the problem obvious!
  • JohnC_V's avatar
    JohnC_V
    NETGEAR Employee Retired
    vdotmatrix,
    It is easy to identify if the switch is running some problems because this is just a plug-and-play device by isolating each port or try replacing an ethernet cable. It is also a good choice to have a 16-port switch to your network.
    John
    NETGEAR Community Team
    • vdotmatrix's avatar
      vdotmatrix
      Guide
      Thank you.
      Have you heard of interfernce cause by some kind of "looping" which messes up somehow the ip addresses ?
        vdotmatrix
        Guide
        POOOOOF!
ProSupport for Business
