vdotmatrix
Nov 10, 2021Guide
Are Ethernet switch problems easy to diagnose?
My ethernet system is crippled. Some ethernet devices are not on the network anymore... It will only work on 3 of 4 ethernet ports out of the R8000 router. I disconnected the 8-port switch which ha...
- Nov 13, 2021
I finally pulled the trigger and installed the new 16-port GS116NA ethernet switch.
POOOOOF!
Problems solved. Apparently it was a bad 8-port ethernet switch that gave up the ghost and was cause all kinds of problems that did not make the problem obvious!
JohnC_V
Nov 12, 2021NETGEAR Employee Retired
It is easy to identify if the switch is running some problems because this is just a plug-and-play device by isolating each port or try replacing an ethernet cable. It is also a good choice to have a 16-port switch to your network.
John
NETGEAR Community Team
