vdotmatrix
Nov 10, 2021Guide
Are Ethernet switch problems easy to diagnose?
My ethernet system is crippled. Some ethernet devices are not on the network anymore... It will only work on 3 of 4 ethernet ports out of the R8000 router. I disconnected the 8-port switch which ha...
- Nov 13, 2021
I finally pulled the trigger and installed the new 16-port GS116NA ethernet switch.
POOOOOF!
Problems solved. Apparently it was a bad 8-port ethernet switch that gave up the ghost and was cause all kinds of problems that did not make the problem obvious!
JohnC_V
Nov 12, 2021NETGEAR Employee Retired
It is easy to identify if the switch is running some problems because this is just a plug-and-play device by isolating each port or try replacing an ethernet cable. It is also a good choice to have a 16-port switch to your network.
John
NETGEAR Community Team
vdotmatrix
Nov 12, 2021Guide
Thank you.
Have you heard of interfernce cause by some kind of "looping" which messes up somehow the ip addresses ?
- vdotmatrixNov 13, 2021Guide
POOOOOF!
