PetGriffin
Sep 24, 2015Aspirant
Inviting users via READYCloud
I have set up various user accounts on my ReadyNAS and want to allow them to access their home folders remotely using ReadyCLOUD. I logged onto ReadyCLOUD, clicked the home folder for user X and pre...
JennC
Sep 25, 2015NETGEAR Employee Retired
Hello PetGriffin,
Please try using How do I add ReadyCLOUD users to my ReadyNAS OS 6 storage system? article instead.
Let us know if you have some questions.
PetGriffin
Sep 25, 2015Aspirant
Hi Jenn
I read that article but I'm afraid it doesn't help! As I mentioned in my OP, I don't have any shared folders on my ReadyNAS. I don't understand why I need to create a shared folder (that won't be used) in order to invite a user to join ReadyCLOUD so that they can access their home folders remotely. It wasn't like that in 6.1.5!
best regards
Alun
- JennCSep 25, 2015NETGEAR Employee Retired
Hello PetGriffin,
We apologize but the invite user option under Manage of ReadyCloud site has been removed long time ago.
To invite a ReadyCloud user, you really need to have a share created because the invite is done per share. That is how it is designed.
Did you create local users? These ReadyCloud users you want to invite, do they have ReadyNAS local home folders?
- PetGriffinSep 25, 2015Aspirant
Hi Jenn
yes, - these are local users with local ReadyNAS folders. The only Clud user is me (admin)
best regards
Alun
- JohnRoSep 25, 2015NETGEAR Employee Retired
Hello PetGriffin,
You'll also have to make sure that there is no share name that is the same with any username, ReadyCloud and local user. Please create shared folders so you can configure the permissions and allow users to access the shares.
If you have more questions, we'll be happy to assist.
Thanks,
