dhl
Oct 30, 2017Luminary
Is ReadyCLOUD down? Network error when signing in.
Is the ReadyCLOUD service down? We're getting this server side error when trying to connect with the app: This has been happening since last Friday. Netgear folks - what's going on?
- Nov 08, 2017
Hello Deniro,
Thanks for your help, v1.5 looks to have downloaded and installed.
Regards
Ben
Retired_Member
Nov 07, 2017hello all
The ReaydCLOUD engineering has already updated latest ReadyCLOUD client for Mac in ReadyCLOUD portal,this version fixed account sign in issue.
bigswami
Nov 07, 2017Aspirant
Thank you for updating the version, but it doesn't install. If you check for updates it says
'' Readycloud client version 1.5 is now available. Do you want to install the new version?''
If you click install it goes through the install procedure but if you check the version after its finished it's still 1.4
and you still get the same error trying to log in.
Can you please check it works? alternatively put the latest version on here: https://kb.netgear.com/20684/ReadyNAS-Downloads
Thanks again
- JackvdNov 07, 2017Apprentice
Same problem here....
App starts and finishes the install proces, but restarting the app still shows v1.4.
When I check the app file, it does show that it was created today.
I will try and install it directly from the website, but I remeber that a couple of weeks ago that still downloaded v1.0....
Jack
- Retired_MemberNov 07, 2017
I don't know what goes wrong, but this is still v1.4....
I even deleted the installed app and did a completely new install. As soon as the app starts, it is telling me that there is a new (1.5) version available.... The app still shows v1.4 in it's info.
Any idea?
Jack
