NASready
Jun 03, 2016Tutor
Issue with ReadyNASRND4000v2 -and Readycloud
Hi to all I have this model ReadyNASRND4000v2 with firmware RAIDiator-arm-V5.3.11 When i loged on Readycloud ,i did the upgrade my account to MyNETGEAR.com,from my desktop windows 10 or 7 it...
NASready
Jun 15, 2016Tutor
Hi
see the first revieuwe and see the link
https://play.google.com/store/apps/details?id=com.netgear.readycloud&hl=en
to prove you that the app was working very goed with my netgear but after the update not any more
Regards
BrianL2
Jun 16, 2016NETGEAR Employee Retired
Hi NASready,
We apologize for this. But the ReadyNAS NV+ v2 only supports ReadyNAS remote. The ReadyCLOUD feature is only available on OS 6 systems. We hope that you will consider StephenB's suggestions or at least configure ReadyNAS remote in your system.
Kind regards,
BrianL
NETGEAR Community Team
- NASreadyJun 16, 2016Tutor
Hi
Readyremote for the netgear that i have to be honnest is not a good application....
Regards
- StephenBJun 16, 2016Guru - Experienced User
Netgear has said a few times now that ReadyCloud is only for OS 6. Frustrating I know, but they aren't going to budge on that.
Let's not keep going in circles. There are a couple of alternatives, and you will either need to use one, or you will need to get an OS 6 NAS.
And a simpel honnest customer have said few times now ,how bought few years a go 2013 a netgear product for more than 400 euro and i m not taliking about a product that is older than 10 years,cant use a simpel application to do a goodand all jobs ......is not a circel is just about a money ...netgear made firmeware to support some product but not other product and you said it very good just buy another product that support OS 6 again spend more money to buy new product .....you forgot another alternative is to buy new product with all support on another companie................
I understand your frustration (my main NAS is running OS 4). I don't work for Netgear, and I agree that you have other options.
I gave you a couple of free choices that (in my opinion) work better than ReadyCloud. My recommendation was/is to use one of them (I personally wouldn't get a new NAS just to get ReadyCloud).
But if you remain stuck on demanding ReadyCloud support for the NV+v2, then I'll have to lock the thread.
- NASreadyJun 18, 2016Tutor
Hi
We are just talking about a product ...
To go a way from the circel let it be constructive for other user and of course for me :manhappy:
So if i wil use the app readyremote on my phone android/iphone i wil be able to backuo automaticaly my pictures/videos from my phone to my readynas product!?
Regards
- StephenBJun 18, 2016Guru - Experienced User
NASready wrote:
Hi
My recollection is that is only lets you access the NAS, and will not do automated backups.
