buz117's avatar
buz117
JIT Debugging Time Out
I am getting this ReadyCLOUD Client error message, and can't figure out what top do. Any suggestions? Thanks
JIT Debugging / "The operation has timed out"
I reinstalled NET Framework, same problem.
The following is the error details I get:
See the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.Net.WebException: The operation has timed out
at System.Net.HttpWebRequest.GetResponse()
at LeafLite.Model.utils.Downloader.DoWork(Object sender, DoWorkEventArgs e) in d:\Jenkins\jobs\ReadyCloud_Client\workspace\sources\ReadyNasDataModelBase\utils\Downloader.cs:line 250
at System.ComponentModel.BackgroundWorker.OnDoWork(DoWorkEventArgs e)
at System.ComponentModel.BackgroundWorker.WorkerThreadStart(Object argument)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 2.0.0.0
Win32 Version: 2.0.50727.4984 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v2.0.50727/mscorlib.dll
ReadyCloudClient
Assembly Version: 1.0.0.1
Win32 Version: 1,13,1285,504
CodeBase: file:///C:/Program%20Files%20(x86)/NETGEAR/Remote/bin/ReadyCloudClient.exe
lnmodel
Assembly Version: 1.0.0.157
Win32 Version: 1.0.0.157
CodeBase: file:///C:/Program%20Files%20(x86)/NETGEAR/Remote/bin/lnmodel.DLL
System
Win32 Version: 2.0.50727.4985 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System/2.0.0.0__b77a5c561934e089/System.dll
System.Windows.Forms
Win32 Version: 2.0.50727.4986 (win7RTMGDR.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Windows.Forms/2.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Drawing/2.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 2.0.50727.4927 (NetFXspW7.050727-4900)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Configuration/2.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Xml/2.0.0.0__b77a5c561934e089/System.Xml.dll
lnresources
Assembly Version: 1.0.0.154
CodeBase: file:///C:/Program%20Files%20(x86)/NETGEAR/Remote/bin/lnresources.DLL
lnresources.resources
Win32 Version: 1.0.0.154
CodeBase: file:///C:/Program%20Files%20(x86)/NETGEAR/Remote/bin/en/lnresources.resources.DLL
System.Runtime.Serialization
Assembly Version: 3.0.0.0
Win32 Version: 3.0.4506.5007 (Win7RTMGDR.030729-5000)
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Serialization/3.0.0.0__b77a5c561934e089/System.Runtime.Serialization.dll
Microsoft.mshtml
Assembly Version: 7.0.3300.0
Win32 Version: 7.0.3300.0
CodeBase: file:///C:/Windows/assembly/GAC/Microsoft.mshtml/7.0.3300.0__b03f5f7f11d50a3a/Microsoft.mshtml.dll
lncontrols
Assembly Version: 1.0.0.152
Win32 Version: 1.0.0.152
CodeBase: file:///C:/Program%20Files%20(x86)/NETGEAR/Remote/bin/lncontrols.DLL
lncomservice
Assembly Version: 1.0.0.153
Win32 Version: 1.0.0.153
CodeBase: file:///C:/Program%20Files%20(x86)/NETGEAR/Remote/bin/lncomservice.DLL
System.Runtime.Remoting
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Runtime.Remoting/2.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
lnutils
CodeBase: file:///C:/Program%20Files%20(x86)/NETGEAR/Remote/bin/lnutils.DLL
System.Core
Assembly Version: 3.5.0.0
Win32 Version: 3.5.30729.4926 built by: NetFXw7
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/System.Core/3.5.0.0__b77a5c561934e089/System.Core.dll
SMDiagnostics
CodeBase: file:///C:/Windows/assembly/GAC_MSIL/SMDiagnostics/3.0.0.0__b77a5c561934e089/SMDiagnostics.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box.
  • buz117's avatar
    buz117
    Oct 26, 2016
    Actually The DNS is already 8.8.8.8 and the Firewall was off during the process yet the error still occured.
    It was working before we did an update on Microsoft NetFramework.
    We solved the problem by restoring back in time to the older version of Net Framework.
    So the conflict is with the newer version of NET Framework.
    Thanks for the support and hope NETGREAR Cloud works out this problem.
  • Retired_Member's avatar
    Retired_Member
    Hello Buz117
    ReadyCLOUD engineering team is investigating this issue,I will update you here  if they find the cause of  issue.thanks!
    Retired_Member
    hello buz117
    The error means the client can not download new installer from readycloud server,ReadyCLOUD engineering added new error handling in ReadyCLOUD client for this issue and they will release new version in the near feature.
    can you please do something on your Windows computer to see if it can fix the issue?
    ***change DNS to 8.8.8.8 on your Windows computer
    ***disable firewall
    • buz117's avatar
      buz117
ProSupport for Business
