DTT
Sep 17, 2019Follower
Leaf Network driver not installing
I have 1 Windows 8.1 computer that refuses to install the leaf network adaptor correctly. I am using the same installation files that I used for others installs that work fine. I have uninstalled c...
Icewaterhot
Sep 19, 2019NETGEAR Employee Retired
I tried it very well on my windows 8.1. What errors will be reported when you install?
If you still can't, you can try the following methods:
You can install ReadyCLOUD_V1.16 and copy "leafnets.sys" with C:\Windows\System32\drivers,then install V1.19 and replace V1.16 "leafnets.sys". Restart it in the device manager, it should be fine.
