mkarimi
Mar 12, 2020Aspirant
Netgear ReadyNas RNDP4000
Hello,
I have a ReadyNas RNDP4000 and I recently factory reset it and now I am not able to access it remotely and nor it is discoverable on the ReadyCloud. Please advice.
Thanks
Manan Karimi
Hi mkarimi,
You can find the instructions on this thread:
For the latest working download links, you can find it on this thread:
Please note that converting your NAS to OS6 is not supported by NETGEAR. Any support on the device will be denied by NETGEAR once you convert it to OS6.
- JohnCM_SNETGEAR Employee Retired
Hi mkarimi,
Welcome to the Community!
May I know the current operating system of your NAS? Is it running on 4.2.x or did you convert it to OS6?
If the current operating system of your NAS is on 4.2.x, ReadyCLOUD will not detect it. Only the OS6 units have support on ReadyCLOUD.
- mkarimiAspirant
Yes, currently it is running 4.2.31.
How I am going to convert it to OS 6?
Do you have any instructions for that?
Thanks
Manan
Hi mkarimi,
