l087550m5i
Mar 06, 2023Tutor
NETGEAR will be terminating ReadyCLOUD - Lack of notice
Sounds like this is EOL: "NETGEAR will be terminating ReadyCLOUD service by April 4th, 2023. ReadyCLOUD mobile app, desktop application, and ReadyCLOUD web portal readycloud.netgear.com will all ...
l087550m5i
Mar 06, 2023Tutor
StephenB wrote:If you are looking for alternatives, the two main ones discussed here are ZeroTier and OpenVPN.
I saw the other discussions, thanks. My issue is that I have been using the cloud accounts as advertised and setup family sharing / cloud backup service for everyone. Using the cloud accounts it was basic but worked. I'm not looking forward to setting up VPN for everyone and dealing with the support of all these Android / iOS and Desktop devices. Before it was, download the app and login.
Right now I'm exploring syncthing and resilio but I'm really on the backfoot here.
Mar 06, 2023Guru - Experienced User
FWIW, I do use resillio sync, but it is set up on a PC, not the NAS. It can be used to back up at least some things on mobile devices (photos for example).
