l087550m5i
Mar 06, 2023Tutor
NETGEAR will be terminating ReadyCLOUD - Lack of notice
Sounds like this is EOL: "NETGEAR will be terminating ReadyCLOUD service by April 4th, 2023. ReadyCLOUD mobile app, desktop application, and ReadyCLOUD web portal readycloud.netgear.com will all ...
l087550m5i
Mar 06, 2023Tutor
StephenB wrote:If you are looking for alternatives, the two main ones discussed here are ZeroTier and OpenVPN.
I saw the other discussions, thanks. My issue is that I have been using the cloud accounts as advertised and setup family sharing / cloud backup service for everyone. Using the cloud accounts it was basic but worked. I'm not looking forward to setting up VPN for everyone and dealing with the support of all these Android / iOS and Desktop devices. Before it was, download the app and login.
Right now I'm exploring syncthing and resilio but I'm really on the backfoot here.
NiveditaP
Mar 27, 2023NETGEAR Employee Retired
Hello JohnS530
The date of terminating the ReadyCloud had been extended to July 1st, 2023.
Note : NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. ReadyCLOUD mobile app, desktop application, and ReadyCLOUD web portal readycloud.netgear.com will all be terminated by July 1st, 2023. After that date, you can continue to access locally your ReadyNAS, or access locally the USB drive connected to the routers, but remote access won’t be available.
Have a lovely day,
Nivedita Pa
Netgear Team
- JohnS530Mar 28, 2023Guide
Great, except the readycloud VPN has not been working for weeks now.
So essentially, readycloud is already dead.
- schumakuJun 30, 2023Guru - Experienced User
The Java-based ReadyCloud desktop client "VPN" application is obsolete and cumbersome for a longer time. It's not required to install and operate the ReadyCloud Desktop application for using the Web-based ReadyCloud portal.
Negative. The https://readycloud.netgear.com/ portal is still up and workable.
- JohnS530Jun 30, 2023Guide
I have been using ZeroTier for almost 4 months, since the ReadyCloud VPN became extremely unreliable for weeks, back in early March 2023. They did finally fix it and as of this moment, it is working, just in time to shut it down.
But you can switch over to ZeroTier using the instructions found on this community site. It does take some minor effort and maybe minor adjustments. (I had to adapt the instructions to my NAS). But it works well. It does not give you access to the Admin Console on the NAS, but good file sharing access in Windows Explorer (Mapped Network Drive).
- seanriddollsMay 17, 2023Initiate
I am unclear on why the ReadyCloud service is being shut down. If it's because it's not profitable (the usual reason for discontinuing a service), why not just convert it to a subscription-based service that brings in monthly revenue to support this infrastructure?
I would gladly pay a monthly fee to continue using this service uninterrupted. - BDK-61Sep 20, 2023Initiate
**bleep** you Netgear
