l087550m5i
Mar 06, 2023Tutor
NETGEAR will be terminating ReadyCLOUD - Lack of notice
Sounds like this is EOL: "NETGEAR will be terminating ReadyCLOUD service by April 4th, 2023. ReadyCLOUD mobile app, desktop application, and ReadyCLOUD web portal readycloud.netgear.com will all ...
NiveditaP
Mar 27, 2023NETGEAR Employee Retired
Hello JohnS530
The date of terminating the ReadyCloud had been extended to July 1st, 2023.
Note : NETGEAR will be terminating ReadyCLOUD service by July 1st, 2023. ReadyCLOUD mobile app, desktop application, and ReadyCLOUD web portal readycloud.netgear.com will all be terminated by July 1st, 2023. After that date, you can continue to access locally your ReadyNAS, or access locally the USB drive connected to the routers, but remote access won’t be available.
Have a lovely day,
Nivedita Pa
Netgear Team
JohnS530
Mar 28, 2023Guide
Great, except the readycloud VPN has not been working for weeks now.
So essentially, readycloud is already dead.
- schumakuJun 30, 2023Guru - Experienced User
The Java-based ReadyCloud desktop client "VPN" application is obsolete and cumbersome for a longer time. It's not required to install and operate the ReadyCloud Desktop application for using the Web-based ReadyCloud portal.
Negative. The https://readycloud.netgear.com/ portal is still up and workable.
- JohnS530Jun 30, 2023Guide
I have been using ZeroTier for almost 4 months, since the ReadyCloud VPN became extremely unreliable for weeks, back in early March 2023. They did finally fix it and as of this moment, it is working, just in time to shut it down.
But you can switch over to ZeroTier using the instructions found on this community site. It does take some minor effort and maybe minor adjustments. (I had to adapt the instructions to my NAS). But it works well. It does not give you access to the Admin Console on the NAS, but good file sharing access in Windows Explorer (Mapped Network Drive).
- StephenBJul 01, 2023Guru - Experienced User
FWIW, there were issues with Macs that I don't think ever got fixed.
More on point, Netgear's announcement said they were discontinuing it today ( 1 July 2023). It still seems to up right now, but I wouldn't count on that lasting very long.
- SandsharkJul 01, 2023Sensei
As for your replacement, I frankly don't understand why anyone would buy a 2-bay NAS. In order to increase space, you'll have to replace both drives. Starting with a 4-bay NAS and two drives, you have two slots you can use for additional drives for increasing space.
ZeroTier is also my remote access method of choice. It has several advantages (IMHO) over ReadyCloud (NAS-to_NAS for remote backup being the one I use most), though you'll also need a separate sync system if you use ReadyCloud for that (I don't use any sync). Plus, it works on other brands. So, you can switch to another brand of NAS and still use ZeroTier, possibly turning your old ReadyNAS into a backup system.
