l087550m5i
Mar 06, 2023Tutor
NETGEAR will be terminating ReadyCLOUD - Lack of notice
Sounds like this is EOL: "NETGEAR will be terminating ReadyCLOUD service by April 4th, 2023. ReadyCLOUD mobile app, desktop application, and ReadyCLOUD web portal readycloud.netgear.com will all ...
Dan001
Jun 30, 2023Guide
I'm thinking of moving to this
Synology DiskStation DS220+ 2-Bay NAS Enclosure
Looks like it has a good file sharing interface, has any one used it? Thoughts?
JohnS530
Jun 30, 2023Guide
Yes, I just bought a Synology NAS as a long-term permanent replacement solution to NetGear ReadyNAS. I find the pricing is good, the hardware is good, the options are good. But if you need a replacement for the ReadyCloud (VPN), they do not have it. You basically have to build a VPN Server on the Synology NAS, and then use either the OS VPN built-in, or a third-party VPN on the client side. Not nearly as nice as the Windows ReadyCloud desktop app I use now.
