l087550m5i
Mar 06, 2023Tutor
NETGEAR will be terminating ReadyCLOUD - Lack of notice
Sounds like this is EOL: "NETGEAR will be terminating ReadyCLOUD service by April 4th, 2023. ReadyCLOUD mobile app, desktop application, and ReadyCLOUD web portal readycloud.netgear.com will all ...
JohnS530
Jun 30, 2023Guide
Yes, I just bought a Synology NAS as a long-term permanent replacement solution to NetGear ReadyNAS. I find the pricing is good, the hardware is good, the options are good. But if you need a replacement for the ReadyCloud (VPN), they do not have it. You basically have to build a VPN Server on the Synology NAS, and then use either the OS VPN built-in, or a third-party VPN on the client side. Not nearly as nice as the Windows ReadyCloud desktop app I use now.
Dan001
Jul 01, 2023Guide
JohnS530 - Thanks for the feedback, much appreciated.
