l087550m5i
Mar 06, 2023Tutor
NETGEAR will be terminating ReadyCLOUD - Lack of notice
Sounds like this is EOL: "NETGEAR will be terminating ReadyCLOUD service by April 4th, 2023. ReadyCLOUD mobile app, desktop application, and ReadyCLOUD web portal readycloud.netgear.com will all ...
Dan001
Jun 30, 2023Guide
I'm thinking of moving to this
Synology DiskStation DS220+ 2-Bay NAS Enclosure
Looks like it has a good file sharing interface, has any one used it? Thoughts?
Dan001
Jul 01, 2023Guide
Since I don't have a NAS but use ReadyShare via my router-USB port I'll now be looking into ASUS:
https://www.digitalcitizen.life/how-to-turn-your-asus-router-into-a-nas/
"Buying a NAS (Network Attached Storage) solution can be expensive and overkill for most home users. A more affordable option is to get an external hard drive or SSD and connect it to your router using the USB port. You can then set up the router to share the drive with your network or the internet to build your own "cloud storage." If you have an ASUS wireless router or an ASUS mesh Wi-Fi system, here's how to turn it into a NAS using a USB hard disk or SSD:"
Stay tuned
