tmadisson
Jul 16, 2017Aspirant
Network configuration and Computer name change
Hi guys! I'm brand new to this forum and was directed here by customer support. I was helped two weeks back to get my NAS back online but when I have tried to log in since it just says it's offli...
- Jul 21, 2017I ended up reinstalling the NAS operating system bundled with it and that has corrected everything that i seem to have been having bother with. Hope anybody reading this post helpful and a possible solution for you.
Marty_M
Jul 18, 2017NETGEAR Employee Retired
Hello tmadisson,
In the Admin page of the NAS under the Cloud tab make sure you have green check marks on Internet and Service and make ReadyCloud in enabled. Please see guide on how to enable ReadyCloud from here.
Welcome to the community!
Marty_M
NETGEAR Community Team
Marty_M
Jul 19, 2017NETGEAR Employee Retired
Hello tmadisson,
After rebooting the NAS to normal mode is the ReadyCloud up and running?
Marty_M
- tmadissonJul 19, 2017AspirantNo, thats not sorted it. I conducted a test and all boot modes came up technical support, 'some other' support or nothing at all according to RAIDar.
- StephenBJul 19, 2017Guru - Experienced User
tmadisson wrote:
No, thats not sorted it. I conducted a test and all boot modes came up technical support, 'some other' support or nothing at all according to RAIDar.That suggests something is corrupted on the disks. I suggest using paid support (my.netgear.com). Ask about per-incident support.
- tmadissonJul 19, 2017AspirantThanks, i guess
