Laks86's avatar
Laks86
Not Reading Storage
Hi everyone,   I have my ReadyNas setup and I have 3x 3TB drives and 1x 12TB Drive but for some reason it does not seem to pick up the storage on the 12TB drive.   Do you know why this could be? ...
  • StephenB's avatar
    Oct 05, 2020
    It's because you need to use two 12 TB drives.  The capacity rule for XRAID is "sum the disks and subtract the largest".  In your case that is 9 TB (~8.18 TiB).  The reason for this is that the system is set up for RAID redundancy - keeping your data available during routine disk replacements or failures.
    The other option is to start over with the 3x3TB drives installed.  Then switch to flexraid, and add the 12 TB drive as it's own jbod volume.  You won't have RAID redundancy on the 12 TB volume it you do that.
ProSupport for Business
