Retired_Member
May 20, 2021account lock out for zero reason
i am getting account lock outs for zero reason how do i fully remove this useless feature?
ajbarnard1977
May 27, 2021Aspirant
Yep, I am getting the same thing. Now I cant get into manage my ReadyNAS at all. So it sounds like the OS re-install solved it? That doesn't mess with the data on the drives right?
- TheDBugMay 27, 2021Tutor
No the OS reinstall does not mess with your data so you can put your mind at rest. Once I did the OS reinstall and I was able to access the interface normally, via username: admin and password: password. Once you are in download the 6.10.4 firmware from here https://kb.netgear.com/000062588/ReadyNAS-OS-6-Software-Version-6-10-4 and install that. Again no data is affected here.
Follow this thread https://community.netgear.com/t5/New-ReadyNAS-Users-General/Firmware-6-10-5-web-interface-broken-in-final-release/td-p/2093599/page/2
- Apr 16, 2020Retired_Member
