ajbarnard1977
Apr 03, 2020Aspirant
Google Drive Sync
I recently enabled Google Drive sync and noticed that when I delete something off my local NAS it does not remove it from Google Drive. Everything is done syncing, and if i edit/change a file on my N...
ajbarnard1977
Apr 15, 2020Aspirant
Will do. I actually just disconnected my NAS from G-Drive, then reconnected it, so I will wait till it's done with the cloud scan part and then send the logs to you.
Thanks,
Drew
ajbarnard1977
One other thing that I forgot to mention before. I noticed there is a hidden folder since I created the G-Drive connection, I am guessing this is ok and just a temp folder? Strange thing is it's only on one of the two shares I connected to G-Drive (one has a hidden folder, the other doesn't).
Screenshot attached
Thanks,
Drew
