beisser
Jun 01, 2020Luminary
ReadyCloud not compatible with Windows 10 20H1 (2004)?
hi guys, ever since upgrading to Windows 10 20H1 all upgraded pcs show my ReadyNAS as Online (VPN-Disconnected) while the 1909 Builds show them as Online. i have tested this on 4 PC's and ev...
waldbauer_com
Jun 23, 2020Luminary
May there is any Readycloud Beta Desktop available ? I read about using only beta client for beta firmware; have currently 1.19 installed.
JohnCM_S
Jun 30, 2020NETGEAR Employee Retired
Hi all,
You can try this ReadyCLOUD test software on the latest Win 10 update and see if this will work. You can download the installer here.
- jtclarkJun 30, 2020Aspirant
I got a few security warnings installing it, but it works.
- waldbauer_comJul 01, 2020Luminary
This version works for me too. Thank you.
- PPP_IncJul 17, 2020Aspirant
This worked for me. However, the version information has not been updated on the test version, so once installed it is identical to the non-working official version 1.19. Is there a timeline on making this fix official, and available to the general public?
- michaelkenwardJul 23, 2020Guru - Experienced User
There has been an update to the ReadyCLOUD client.
v 1.20 should offer itself if you check for updates.
No more VPN errors.
