antond's avatar
antond
Tutor
Jan 05, 2016
ReadyCLOUD compatibility with Windows 10 build 10586
I have just installed W10 build 10586 and it breaks the ReadyCLOUD client. It starts initializing but then quits. This seems to happen every time there is an update to W10. Every other program on my PC carries on working, but not ReadyCLOUD. When can we expect a verison of RC that works with the new W10? I don't like the insecurity of not automatically backing-up to my NAS box. Thanks for feedback.
  • My PC just did another Windows update this evening, the second update in a week, and you know what? The ReadyCloud client came back to life without me doing anything. Clearly something was fixed in the update that had killed RC. The version number of Windows 10 didn't change. It still says Version 10.0.10586 Build 10586, which explains a previous comment that says they had no problems. Why this build came in two parts is strange. Why didn't it all download in one go?
    I am happy that things are back to normal, but unhappy that MS put out an update or an incomplete update that affected Netgear software in this way. I worked my way around it, by finding an alternative way of backing up, but it was annoying nonetheless.
  • StephenB's avatar
    I'm all in favor of backups - but want to point out that you don't have to use readycloud for that.  There are other tools that can be used to back your PC data up to the NAS.
    That said, ReadyCloud should simply work of course.
  • mdgm-ntgr's avatar
    mdgm-ntgr
    NETGEAR Employee Retired
    Have you installed the latest version of the ReadyCLOUD client?
    • antond's avatar
      antond
      Tutor
      I am running version 1.9.1249.412 installed on 12/12/2015. If that is not the latest version where can I get it? Thanks.
      mdgm-ntgr
      That is the latest version of the client.
      • antond's avatar
        antond
        Tutor
        So what should I do now? Will an updated ReadyCloud client automatically download and install in the next few days?
  • Hello, I have been having the same issue and have similiar versions of the programs Windows 10, version 1511, Build 10586.36 and ReadyCLOUD version 1.9.1249.412 - since these upgrades the ReadyCloud client is unable to connect locally, via cellular or external wi-fi connections, my ReadyNAS (NAS202) shows up as a network drive and I can connect to the drive with read/write access no problems over my local network, I can connect to the web version of ReadyCLOUD and access files remotely via this method if required. Luckily my old Windows 7 laptop with the old ReadyNAS remote client still chuggs away reliably - I would love to find a solution too :-)
    • BrianL2's avatar
      BrianL2
      Hi antond & webZplus,
      Thank you for the details that you have provided. Still checking and trying to duplicate this issue that you've encountered.
      Kind regards,
      BrianL
      NETGEAR Community Team
      • antond's avatar
        antond
        Tutor
        BTW, I have a RN314 with fully up-to-date firmware (6.4.1).
  • kohdee's avatar
    kohdee
    Administrator
    I am using ReadyCLOUD on 10586 and my application opens and I can look at connected NAS devices both VPN and Local.
    Maybe check in device manager on the status of your leafnet adapter and if your leafnet adapter is active and has a 5.x IP.
    • antond's avatar
      antond
      Tutor
      • BrianL2's avatar
        BrianL2
        Hi antond,
        Thanks for the update antond. I hope others who have experienced the same problem will receive the same Windows update and have their ReadyCLOUD access working again. Could you check the update history of your computer so you can share with us what kind of update that was?
        Kind regards,
        BrianL
ProSupport for Business
