portiah
Aug 28, 2017Aspirant
Remote Access Readynas RND2000 duo V2
As you can see I have a Nas drive which is a few years old. I have never used it remotely but I would like to now. Am i right in thinking that the Readynas remote app has been replaced by ReadyCLOU...
JennC
Sep 04, 2017NETGEAR Employee Retired
Hello portiah,
Are you required by your ISP or router vendor to put NAS on static IP? What happens when you set the NAS to Obtain DNS automatically? If there is no option then you might need to set it to Obtain IP address automatically first.
JennC
Hello portiah,
I'm wondering why you can't change the DNS. Did you reboot already? What web browsers have you tried? Maybe you want to try another one.
- MartyblythSep 06, 2017Aspirant
Hi there,
Im getting all the same problems, and im on the virgin meida superhub as well, On the plus side i did find a way to change my DNS settings on the overview page of the ReadyNAS chaing it to what you recommend but still no luck.
Any updates would be helpful
Thanks Marty.
- JennCSep 06, 2017NETGEAR Employee Retired
Hello portiah,
Can you post a screen capture of the network settings of the NAS?
May I also ask where the NAS is connected? If it is connected straight to the router or to a switch that is connected to the router.
Hello,
I guess your replying to me as the other person hasent replied but,
This in my screenshot
Also its right in to the router.
thanks Marty
- portiahSep 07, 2017Aspirant
Thanks for the info. I still can't edit the dns on the readynas dashboard. It just won't let me change anything on the dns popup window.
Hi
The Nas drive is connected direct to the router. Which screen do you want me to capture - is it the main dashboard screen?
I also meant to mention that I have tried this on several browsers - google chrome, firefox, windows explorer.
