claynz
Aug 19, 2022Guide
ReadyNAS Duo (RND2000 v2) Drive Access
Pulled this out of the cupboard and gave it a dust down and fully reset it, to find out I can not access it using Windows 10/11 due to limitations with web browser.
how can I by pass it?
You will have to use an older browser that supports TLS1.0 to access the admin page, IE11 or an older version of Firefox might help.
Are you having errors accessing data using file explorer? You may have to enable support for SMB1
- Marc_VNETGEAR Employee Retired
- claynzGuide
Firefox v43 did the trick but can not login with default username admin
I have also tried passwords
password
admin
netgear1
Access to drives are working now after installing SMB1
password
admin
netgear1
Does the NAS say
- ReadyNAS Duo on the front panel? or
- ReadyNAS Duo v2 on the front panel?
