muhammedsameer
Jun 14, 2019Aspirant
Ready NAS 102 not connecting in some system
Jun 14, 2019Guru - Experienced User
We'll need more information than this.
- what firmware you are using (please provide the actual firmware - don't just say "latest").
- what exactly isn't connecting - the ReadyCloud app??? or something else???
- any differences between the systems that connect and the ones that don't (for instance, Operating System).
- muhammedsameerJun 14, 2019Aspirant
Device Firmware :6.10.1
When Connecting the device through local network (WiFi and LAN) it not connecting. Device is showing in network devices Windows 10,But when we clicking it's can't access.
- StephenBJun 14, 2019Guru - Experienced User
If you are using file explorer, then try entering \\nas-host-name and \\nas-ip-address in the file explorer address bar (using the real host name and ip address of course). Be careful to use the correct slash direction.
Try them both, and let us know the results.
- muhammedsameerJun 15, 2019Aspirant
Not able to connect.
