muhammedsameer
Jun 14, 2019Aspirant
Ready NAS 102 not connecting in some system
muhammedsameer
Device Firmware :6.10.1
When Connecting the device through local network (WiFi and LAN) it not connecting. Device is showing in network devices Windows 10,But when we clicking it's can't access.
Jun 14, 2019Guru - Experienced User
If you are using file explorer, then try entering \\nas-host-name and \\nas-ip-address in the file explorer address bar (using the real host name and ip address of course). Be careful to use the correct slash direction.
Try them both, and let us know the results.
- muhammedsameerJun 15, 2019Aspirant
Not able to connect.
- StephenBJun 15, 2019Guru - Experienced User
Then try running CMD (enter "CMD" in the windows search bar) and enter this:
net use * /delete net use z: \\nas-ip-address\data /user:admin nas-admin-password
The first command terminates any open SMB sessions. If it prompts, then let it continue.
The second attempts to mount the NAS data volume as drive letter z. Use the real NAS IP address and admin password of course. Be careful on the typing (particularly spaces and slash direction). If you use FlexRAID, then use your volume name instead of data.
Let us know the results here (including any errors).
