Jdotcox90
Mar 02, 2022Guide
Readycloud for Mac OS
I just purchased a macbook pro for work. I am not able to get readycloud to make it all the way through the installer. It says installation failed when trying to install. I am running Montere...
Marc_V
Mar 03, 2022NETGEAR Employee Retired
Welcome to the Community!
Can you post a screenshot of the error? This is for us to check if we need to file a bug, hopefully anyone on Monterey 12.1 will also post here.
Have you tried contacting Support or creating a case on your mynetgear profile as well?
HTH
- Jdotcox90Mar 04, 2022Guide
I have not filed a ticket or anything. I am an employee so do not have all of our admin info.
There are no codes. it just says installation failed.
Had out IT specialist try to install as well and he was unsuccesful. I had a buddy with a newer macbook try as well, his failed.
