Jdotcox90
Mar 02, 2022Guide
Readycloud for Mac OS
I just purchased a macbook pro for work. I am not able to get readycloud to make it all the way through the installer. It says installation failed when trying to install. I am running Montere...
Jdotcox90
Mar 04, 2022Guide
I have not filed a ticket or anything. I am an employee so do not have all of our admin info.
There are no codes. it just says installation failed.
Had out IT specialist try to install as well and he was unsuccesful. I had a buddy with a newer macbook try as well, his failed.
Marc_V
Mar 11, 2022NETGEAR Employee Retired
A case has been opened and the appropriate team is looking into this issue. Hopefully we can get an update ASAP.
HTH
- Jdotcox90Mar 16, 2022Guide
Is there any update on this.
Thank you
- Marc_VMar 29, 2022NETGEAR Employee Retired
This issue is currently under investigation, I will make sure to post an update once a fix or a new version is available.
Apologies for the inconvenience.
- mkrtApr 01, 2022Star
may this have something to do with M1 compatibility? forgot to mention that
- Marc_VApr 01, 2022NETGEAR Employee Retired
- Jdotcox90Apr 01, 2022Guide
Says I cant download because not trusted
