Jdotcox90
Mar 02, 2022Guide
Readycloud for Mac OS
I just purchased a macbook pro for work. I am not able to get readycloud to make it all the way through the installer. It says installation failed when trying to install. I am running Montere...
Marc_V
Mar 11, 2022NETGEAR Employee Retired
A case has been opened and the appropriate team is looking into this issue. Hopefully we can get an update ASAP.
HTH
Jdotcox90
Mar 16, 2022Guide
Is there any update on this.
Thank you
- Marc_VMar 29, 2022NETGEAR Employee Retired
This issue is currently under investigation, I will make sure to post an update once a fix or a new version is available.
Apologies for the inconvenience.
- mkrtApr 01, 2022Star
may this have something to do with M1 compatibility? forgot to mention that
- Marc_VApr 01, 2022NETGEAR Employee Retired
- Jdotcox90Apr 01, 2022Guide
Says I cant download because not trusted
Please access and continue, if you still can't download it please let me know through PM.
So the issue not completing install is resolved for this build.
When using the ReadyCloud portal can you access the NAS?
Have you tried rebooting or reinstalling the app?
- boris_005Apr 01, 2022Tutor
The app completes installation but I'm now getting a message that my fileserver is online but the VPN is disconnected. (See attachment) I think this might have something to do with M1 Macs as other employees are able to use the ReadyCLOUD app without any issues.
System:
MacBook Pro (16-inch, 2021)
Apple M1 MaxmacOS Monterey 12.2.1
- OsmiumJun 28, 2022Guide
Same issues we have this problem for 3 months already
