Jdotcox90
Mar 02, 2022Guide
Readycloud for Mac OS
I just purchased a macbook pro for work. I am not able to get readycloud to make it all the way through the installer. It says installation failed when trying to install. I am running Montere...
Tommo71
Mar 23, 2022Aspirant
also having the same problem, someone on here said that v1.6 & 1.7 work, is there a way to download older versions so that I may try them on MacOS Monterey?
Osmium
Mar 29, 2022Guide
I have 2 tickets open about this topic asking if i can have a older version of readycloud for mac.
So far they let me know they are working on this issue.
They seem to not want me to have a older version of ready cloud.
And yes i got 2 mac's running on v1.6 and v1.7 but i dont have the installation file of this older ReadyCloud 😞
My other 3 mac's and a few other people i know try to install the newest version of ReadyCloud. That one seems to not go futher then Installation Failed.
i am sorry to let you all know this issue is already more then 3 weeks and so far no fix 😞
- OsmiumMar 29, 2022Guide
So far i tryed out to repackage the old App into a PKG file so we can reinstall it but that seems to not work 😞
Inside Terminal i used commands to download from Anywhere and install anything but also that seems to not help.
i tryed this issue now on 7 macs with versions [11.4], [12.1] and [12.2.1] and on all these mac versions the latest Readycloud says Installation Failed.
