Jdotcox90
Mar 02, 2022Guide
Readycloud for Mac OS
I just purchased a macbook pro for work. I am not able to get readycloud to make it all the way through the installer. It says installation failed when trying to install. I am running Montere...
Tommo71
Apr 04, 2022Aspirant
- Tommo71Apr 04, 2022Aspirant
Yes, that worked, found I needed to copy it to the applications folder and run it from there, still got the error, but was then able to override it.
Installed cleanly and can now see that I'm running v1.8 and am able to connect to my ReadyNAS.
Many Thanks
- mkrtApr 06, 2022Star
just want to confirm for everybody that pkg from Marc_V works. also don't forget to tick 'Enhance MacOS' option for SMB protocol in your device settings.
- boris_005Apr 06, 2022Tutor
If by working you mean installing, then yes. If by working you mean it fixed all the issues i'm experiencing, then no. I still can't connect to the VPN.
