perrij3
Apr 17, 2017Guide
ReadyCloud Invite Link Not Working
We were recently were affected by the ReadyCloud issue where our ReadyNAS left the ReadyCloud system. Due to this, all our offsite users accounts were deleted. When I go to recreated them, they are...
- Apr 28, 2017
After Netgear support fixed another issue with the drive, this problem has gone away. I'm not sure how the 2 issues are related, but the issue that was fixed was the drive stopped working properly (was not able to access any shares) due to the antivirus program installed on the drive.
Details about that issue can be found here:
https://community.netgear.com/t5/Using-your-ReadyNAS/All-shares-disappeared-after-updating-to-Firmware-version-6-6-1/m-p/1271884Thank you to all those that made suggestions about how to resolve this issue.
JennC
Apr 20, 2017NETGEAR Employee Retired
Hello perrij3,
Did you backup all the ReadyCloud user home shares and then re-register your main ReadyCloud account to the admin page > Cloud?
You may also try emailing [email protected] about the users you invite that get issues, include screenshots of the errors.
perrij3
Apr 20, 2017Guide
No user used their home share, so there was no need to back that up. We do back up the all shares though on the NAS. I have re-registered our NAS with ReadyCloud. It works if I create a new account for an email that was not registered prior, but we are having issues with accounts that had been set up before the issue.
I did send an email to that email address a week ago, still haven't heard anything back.
- JennCApr 21, 2017NETGEAR Employee Retired
Hello perrij3,
Can you PM me the ReadyCloud user accounts and some screenshots of the email they get when you invite them? Along with the errors.
- JennCApr 24, 2017NETGEAR Employee Retired
Hello perrij3,
I need you to update this thread with the screenshots and what turned out to be the issue so I can check this others from Netgear.
The issue with SMB not enabling may need to be fixed from the back end.
- perrij3Apr 28, 2017Guide
