beisser
Jun 01, 2020Luminary
ReadyCloud not compatible with Windows 10 20H1 (2004)?
hi guys, ever since upgrading to Windows 10 20H1 all upgraded pcs show my ReadyNAS as Online (VPN-Disconnected) while the 1909 Builds show them as Online. i have tested this on 4 PC's and ev...
Sandshark
Jun 02, 2020Sensei
This is why being the first on the block to upgrade is not usually a good idea. Doing it on four machines is a really bad idea. Microsoft has found and is fixing bugs in that release, and I suspect Netgear will wait to see if the problem is Microfoft's or Netgear's.
You do have the ability to remove the upgrade. See here: how-to-uninstall-windows-10s-may-2020-update.
- beisserJun 02, 2020Luminary
as you can see i already rolled back the update on one machine for testing, so telling me how to roll back/uninstall is kind of redundant :)
the way i see it something has changed in windows and netgear will have to adapt their software to make it work on the new version.
i do not expect this to be a fast process, but it will need to be done regardless.
of course it could be some bug in windows, but i suspect that simply some underlying mechanic changed and the software cant cope with it yet.
that is why i am reporting this nonworking state because sooner or later everyone will be autoupgraded to 2004 and then the software should be working properly.
- SandsharkJun 03, 2020Sensei
beisser wrote:as you can see i already rolled back the update on one machine for testing, so telling me how to roll back/uninstall is kind of redundant :)
Yes, but others read the posts (at least they should, we see lots of duplicates indicated some do not) to potentially find a solution to their problem.
If Microsoft has not released a lits of known bugs and one of them affects this, then I agree that Netgear should address it as a required fix until proven otherwise.
- JohnCM_SJun 03, 2020NETGEAR Employee Retired
Hi all,
We have inquired about this issue to the appropriate team. We will provide an update as we get feedback from them.
- TzioufastJun 11, 2020InitiateCan you provide status
