coalition
Oct 24, 2016Tutor
Readycloud only downloads a 1k file
Inside of ReadyCloud browser version all of my MSWord documents are downloading as 1k corrupted files.
I'm using Chrome browser and Windows 7. Also does not work on Internet Explorer.
<?xml version="1.0" encoding="utf-8"?>
<request moniker="/root/devices" method="upload" code="1">
<body type="download">
<guid>7d17b917-f73f-41a0-8f5f-a372e15c13da</guid>
<value><![CDATA[********file name here************.docx]]></value>
</body>
</request>
- Retired_MemberOct 24, 2016
Hello coalition
What is the version of ReadyNASOS running on your NAS device? I think ReadyNASOS 6.6 has already fixed the issue.
Other users reported the same issue and they confirmed the issue is fixed in ReadyNASOS 6.6. Please check the following forum link
- YeZNETGEAR Expert
Can you please contact us at [email protected] so we can help to check this issue? Thank you.
Please include this post link in the email:
https://community.netgear.com/t5/ReadyCLOUD/Readycloud-only-downloads-a-1k-file/m-p/1159753#U1159753
- Retired_Member
Hello coalition
I updated the firmware today and am now able to download my files again. Thank you for the tip.
- JennCNETGEAR Employee Retired
Hello coalition,
If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.
The Netgear community looks forward to hearing from you and being a helpful resource in the future!
