bhague01
Jul 07, 2021Aspirant
ReadyCloud signin
Ready Cloud has been working well in the past, but I have been out of action in recent weeks. When I came back to use the laptop with the ReadyCloud client installed, I have first had some issues wi...
- Sep 05, 2021
Hi StephenB
Thank you. I think we are sorted! Everything is now accessible - hurrah!
I am now using the IP addresses to identify both the source and the endpoint of the FreeFileSync program, and all appears to be working fine again.
I have learnt some things about the various technical terms, which are not always well explained, as well as the importance of careful use of syntax.
I still don't understand why things went wrong in the first place, but all is well that ends well.
We should probably entitle this conversation "The case of the missing T: drive"!
I am very grateful to you for your time and input. I would like to have given you a lot more kudos, which I only noticed at the end.
I am sure you will be a great help to many more folk, who come looking for it!
Cheers and very best wishes
DaneA
Jul 13, 2021NETGEAR Employee Retired
Kindly try to completely uninstall the ReadyCloud Client app then reinstall its latest version in your laptop. Check if it will solve the problem.
DaneA
NETGEAR Community Team
bhague01
Sep 01, 2021Aspirant
DaneA
Thanks for that, DaneA. I am now able to access my ready cloud data on the NAS once again. Whew!
On a related matter, however, I have had a backup system set up for my music which stores the data on the NAS as a mirror to a separate hard disc, attached wirelessly.
When I came to back-up again after recovering my access to ReadyCloud, it asked me for a password to the NAS. I had thought that I had changed the NAS password to my ReadyCloud password, but that appears not to be the one the system (W10 64bit) is asking for. How can I recover _that_ password to make the system work once again? I did try entering a new password in the Credential Manager, but that did not work.
Any further suggestions? Should I be posting this elsewhere?
Cheers
- StephenBSep 01, 2021Guru - Experienced User
First try logging into https://nas-ip-address/admin, so you can be sure that you know the NAS admin password. Use the real IP address of the NAS of course. Don't use ReadyCloud for this test.
Is the backup using the NAS admin account credentials, or have you created a user account?
Also, I suggest using two account credentials - one set up for the NAS hostname, and the other set up for the NAS IP address. If you haven't reserved the IP address for the NAS in your router, then I recommend doing that too.
- bhague01Sep 01, 2021Aspirant
Thanks, StephenB
I logged into the NAS admin as suggested, using the appropriate password (which is also the ReadyCloud password, as it happens).
I then accessed the backup app, using these credentials, and got the following:
Windows Security
Enter network credentials
Enter your credentials to connect to: MYNAS
bill.xxxxx@xxxxxxx
Tick - Remember my credentials
Access is denied
More choices
I have not created a user account as far as I know.
Can you please clarify about using two account credentials? Do you mean for the back up program? Is this where I click on "More choices" and add the IP address as an option?
I have now reserved the IP address for the NAS in the router: do I now need to delete it from the Client list, or does that stay as is?
Apologies for my ignorance!
Bill
- StephenBSep 02, 2021Guru - Experienced User
Then you either need to use the NAS admin account credentials or you need to create a NAS user account. FWIW, it is better security to not use the NAS admin account for access.
Your Microsoft logon will not work for this. I don't think your ReadyCloud credentials will work either, unless you are accessing via ReadyCloud.
You can leave it as it is.
There are two ways your PC can access the NAS. You can use the NAS hostname (MYNAS in your case), or you can use the IP address. As far as Windows is concerned, they are two different PCs. So if you store a credential for MYNAS it won't be used when you access the NAS using its IP address. So I recommend adding a credential for the IP address as well as the hostname.
I don't know what backup program you are using. Some simply use the credentials stored in the credential manager. But there are some that configure/store their own credentials (Acronis TrueImage is the one I use, and it does have it's own credential store).
- bhague01Sep 02, 2021Aspirant
Thanks, StephenB
I have created two new users within the admin page, BH (email address X@X) and bhague01 (email address Y@Y: which is an alias to my standard Z@Z address).
However, the Windows Security login window which pops up for the mirroring program does not like either of these options - "Access denied". :(
I have checked that the Win10 Credential Manager has accepted both these options: all OK, except that, in both cases, the password is given as ********, rather than **********, as I might have expected, given that in both instances it is a 10 character length.
I was wondering if reinstalling the software could be done without affecting the stored files?
I look forward to your further illumination!
Cheers
