lorenz's avatar
lorenz
ReadyCoud Architecture & data privacy/security
Hi there,
I have a basic question, yet I do not seem to find diagrams or articles about it: How does ReadyCloud work?
specifically I would like to understand what information I am sharing with netgear by using the service and who thus (even hypothetically) will have access to my data when using readycloud. any pointers to diagrams/white papers/articles or similar would be greatly appreciated...
thanks,
Lorenz
  • StephenB's avatar
    Unfortunately Netgear doesn't provide any information on this.  They should.
    • lorenz's avatar
      lorenz
      thanks stephen, that is interesting. if I were paranoid that would raise all sorts of questions. for now I guess I will just refrain from using ReadyCloud. resilio sync seems to work well...
      • Sandshark's avatar
        Sandshark
        Sensei
        I can tell you that ReadyCloud just negotiates the initial connection between devices.  The data itself does not flow through their servers (it would take masive throughput to do that).  If you want similar (in my opinion, better) connectivity that is more transparent about their access model, you can look at ZeroTier.
ProSupport for Business
