PLeyro
Jun 10, 2016Aspirant
ReadyNAS 102 - ReayCloud won't turn on with Firmware 6.5.0
Hi, I see the old tread: https://community.netgear.com/t5/ReadyCLOUD/ReadyCloud-won-t-turn-on/m-p/1018938#M2041 has been signed as closed. Why? The problem is not solved. In the meantime I re...
- Jun 15, 2016
This is a problem where if it occurs it needs to be fixed remotely. The fix should then survive firmware updates.
Applied the correct serial number and rebooted. It appears to now be fixed.
JennC
Jun 10, 2016NETGEAR Employee Retired
Hello Pleyro,
That was closed by the original poster which just right. Not all ReadyNAS systems have this problem.
Maybe PM mdgm to arrange a remote session and fix this.
Welcome to the community!
- PLeyroJun 11, 2016Aspirant
Hello JennC,
Thanks for your quick reply.
I will send a PM to mdgm-ntgr more quickly and follow its instructions.
Long live the community!Regards,
Pascal :-)
- mdgm-ntgrJun 13, 2016NETGEAR Employee Retired
PLeyro, I have just sent you a PM.
- mdgm-ntgrJun 15, 2016NETGEAR Employee Retired
