Max_Maas
Mar 11, 2016Tutor
ReadyNAS 102 - ReayCloud won't turn on.
Dear Support,
I see the old tread: https://community.netgear.com/t5/ReadyCLOUD/ReadyCloud-won-t-turn-on/m-p/1018938#M2041
has been signed as closed.
Why? The problem is not solved.
In the meantime I received the notification of a newer Firmware (6.4.2)
(the ReadyCloud issue was created by the ver. 6.4.1).
But the issue is still exacley the same.
After the .6.4.1 updat:
- all network configuration were messed-up
- the Webpage and Label Serial number didn't match anymore
- the ReadyCloud unable to be turned ON.
I bought your NAS due to the remote access to my files.
Now are already months that you created this problem and you discontinued a service which drove me to buy this device.
I would appreciate if you, after this quite long time, will offer a real solution.
Thanks in advance
Max
You should be able to turn on ReadyCLOUD again now.
has been signed as closed....
Why? The problem is not solved...
It was actually Synergie's thread (though you posted to it) - and the marked solution was for Synergie's problem (which is not the same as yours). You can open a new thread for your problem.
Also this is a community forum, not a Netgear support forum (though several Netgear support people are active here).
Note that ReadyCloud is changing significantly in 6.5.0, you can see the details in the beta thread.
- mdgm-ntgrNETGEAR Employee Retired
Max_Maas I have sent you another PM.
There is a fix we can apply to systems that run into this issue provided they are running 6.4.2 or later. I have let you know what I need to fix this. - mdgm-ntgrNETGEAR Employee Retired
Max_Maas I haven't heard back from you yet. Did you get a chance to read my PM?
- Max_MaasTutorHi Mdgm,
Correct this morning I turned it on with the first shoot.
Thanks for your support.
Max - mannythetechAspiranthi i am having the same problem i click the button to on and it wont turn over
